heat map plugin from QGIS python console
I am trying to use the heat map plugin from the processing console. On the QGIS documentation it says the plugin uses Kernel Density Estimation. I have used the saga Kernel Density Estimation but do not get results that look similar to the heat map.
How can I import the plugin into python console.
For vector it's from fTools import *.
How can I use raster plugins in processing i.e heat map plugin and georeferencer.
