I am working on Ubuntu Precise with postgresql version 9.3 and postgis 2.0.
After initially starting my postgres database and eventually getting permission errors that would prevent postgres from starting due to my modifying the pg_hba.conf file I followed a tutorial from ArchLinux ArchLinux postgres setupwhich stated to create a directory to house my database cluster. Previously I did not do so and had less trouble connecting to QGIS. I know postgres out of the box comes with a default database cluster, so I am wondering if I am attempting to connect to the wrong cluster?
I have config files in two different directories as a result of the tutorial I followed:*with root user: /etc/postgresql/9.3/main*under postgres (default auto-created linux user): /var/lib/postgres/data
In any case after making my modifications I also restarted my postgres server and every time I start my server I do so from etc/init.d/postgresql. If so, how exactly do I go about fixing that without breaking my postgres installation?
My error is connection refused, but my port(5432) is listening when I checked with telnet. I am trying to connect with the add Postgis layer GUI option in QGIS Dufour installed on a windows box.
*my pg_hba entry is host all all 0.0.0.0/0 md5*local_addresses was set to * in postgresql.conf
When I tried to connect on my database server via its local in the postgres user I tried psql -h 127.0.0.1 -U postgres -d postgres
...and I got "could not connect to server, etc", which leads me to believe the loopback is failing because wildcard should allow localhost as well.
Are you supposed to be able to connect to the server on a local machine or...?Do I have to change my iptables default settings?
*No particular errors on my postgresql installation stuck out.
