PROBLEM:.
- I have a Georeferenced image of a part of a city having images of Streets, slums areas, water bodies and greeneries.
- Simultaneously I had City based city based map (CAD assisted) containing the boundary of different part (wards) of the area of that city part.
- Based on the Geo-referencing of the image as mentioned in Item(1), I have to register the map and create shapefiles (with spatial database) of Streets, slums areas, water bodies and greeneries in map of item(2).
- However ArcGIS is not possible to be use for this work and accordingly Open Source Software are required to develop a Real-Time GIS Web based application.
- Then those Shapefiles (with data-sets) are to be referenced in a real-time web based application system such that those shapefiles are instantly referenced conjugating with another separate data references (e.g. climatic data).
- I solicit your help to specify one optimum open source software with guidelines and tutorials to use them (I have used QGIS but not getting any well documented tutorials).
- Which Server can be best used as my localhost Optimally?
- Which Database will be best to develop the application?
- Which Server-side and Client-side programming languages are best to develop this web based application?
- I solicit your help to get a simple step-by-step guide to develop afore-stated GIS Web based application.
