I am trying to print a map like the image below. And I have a problem with grid and graticule.I understand that the best way to have a grid (in UTM, meters) and a graticule (in GMS) is by adding both grids and changin the SRC to each one.
The problem with this method is that I can't find an option to add the padding marked in the photo.
The other way that I was trying is adding two Maps to the composer, the first one with the layers, and with the UTM grid in blue, and a second Map canvas backwards, in blank, showing the GMS graticule in WGS84.
I don't know if there is a better option to compose a simmilar map.
Does anybody know which would be the best method?
Thanks
Thanks
