When I execute r.to.vect the following error appears:
r.to.vect input=sreviLC815109_-120_-120 output=temp feature=area --o --qDBMI-DBF driver error:ERROR: Unable to create table: create table temp ( cat integer, value double precision)Any ideas what this could be?My main issue is that this error appears absolutely sporadically in a script while the action is performed on many files. I could shift the error message a bit to a later point in time by deleting the temp vector map before, but it still appears. I am working with Grass 6.4.3.
EDIT:When I do the action manually, everything works fine.
