Dear all, I'm getting this error below, please help about it. I've installed liblas 1.8.0 and python setup.py inside of liblas installation folder. Thanks
Traceback (most recent call last): File "/usr/lib/grass70/gui/wxpython/gui_core/treeview.py", line 56, in
self._emitSignal(evt.GetItem(), self.itemActivated)) File "/usr/lib/grass70/gui/wxpython/gui_core/treeview.py", line 120, in _emitSignal
signal.emit(node = node) File "/usr/lib/grass70/etc/python/grass/pydispatch/signal.py", line 229, in emit
dispatcher.send(signal=self, *args, **kwargs) File "/usr/lib/grass70/etc/python/grass/pydispatch/dispatc her.py", line 349, in send
**named File "/usr/lib/grass70/etc/python/grass/pydispatch/robusta pply.py", line 60, in robustApply
return receiver(*arguments, **named) File "/usr/lib/grass70/gui/wxpython/gui_core/menu.py", line 166, in
self._tree.itemActivated.connect(lambda node: self.Run(node)) File "/usr/lib/grass70/gui/wxpython/gui_core/menu.py", line 223, in Run
eval(handler)(event=None, cmd=data['command'].split()) File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 776, in OnMenuCmd
GUI(parent=self, giface=self._giface).ParseCommand(cmd) File "/usr/lib/grass70/gui/wxpython/gui_core/forms.py", line 2348, in ParseCommand
raise gcmd.GException(e.value) core.gcmd . GException : Unable to fetch interface description for command 'r.in.lidar'. Details: [Errno 2] No such file or directory (Fri May 29 13:01:39 2015)
raster
[Errno 2] No such file or directory (Fri May 29 13:01:39 2015) Command finished (0 sec)
raster
