I am working on a 13407 lines * 11050 columns raster file (SRTM DEM, 30m) with a script that calls a series of hydrological modules in GRASS 7.0. The system I am using is a Windows server 2012 R2, 64 bit Intel Xeon 2.5 GHz processor, 32GB of RAM.
The first module called in the script is r.watershed. When lunched on that data set, it generates the following error : G_malloc: impossible to allocate 1185910608 bytes to raster/r.watershed/ram/init_vars.c:149
How can I get this error when there are 30 GB of ram available?
I managed to pass that first hurdle using the -m flag on r.watershed. The scripts now requires 7 GB of disc space, and even if it's slow and I don't understand why it can't use the ram in the first place, r.watershed finishes correctly.
However, when the script gets to the next module, r.fill.dir, GRASS crashes at 'Reading input elevation raster map...' with the following message:
Problem signature: Problem Event Name: APPCRASH Application Name: r.fill.dir.EXE Application Version: 7.0.0.0 Application Timestamp: 54e7aaf0 Fault Module Name: r.fill.dir.EXE Fault Module Version: 7.0.0.0 Fault Module Timestamp: 54e7aaf0 Exception Code: c00000fd Exception Offset: 00001479 OS Version: 6.3.9600.2.0.0.400.8 Locale ID: 1036 Additional Information 1: 3397 Additional Information 2: 33978ebc9cf04f9490066e458551979d Additional Information 3: caf7 Additional Information 4: caf72cf53bf264b7d49f3bd72b0afc04
Has anyone have an idea how to fix these two issues?
