I'm trying to combine google's geocoding service with openlayers. So when a user types an address and hits enter, map zooms there and renders a simple point. I edited my code according to the previous link. Does not work. I'm using a vector layer as basic (comes from Geoserver/PostGIS), a google's layer as second basic. I also added a simple vector layer to render the adrress's point. Do I have to bind google's layer and geocoding service somehow?
Here is my code. Can you spot what's wrong?
Thank you...
var geocoder; function codeAddress() {alert ('inside function');//works var address = document.getElementById("address").value; //tell to user, he did not type anything if (address==""){document.getElementById("geocodMsgG").innerHTML = "You gave no input";} else{ alert(address);//works geocoder.geocode( { 'address': address}, function(results, status) {alert(status);//not work if (status == google.maps.GeocoderStatus.OK) { alert('inside 2 function');//not work alert(results[0].geometry.location);//not work //create a geometry point pointgc = new OpenLayers.Geometry.Point(results[0].geometry.location); //create a feature point feature_point_gc = new OpenLayers.Feature.Vector(pointgc); //lfl contains bounds that i set earlier in my code if (lfl.containsLonLat(results[0].geometry.location)){ //render the point on the layer named geoco geoco.addFeatures([feature_point_gc]); geoco.refresh({force:true}); //zoom there map.setCenter(results[0].geometry.location); } //if point is not inside the bounds (lfl) then dont add - print msg to user else{document.getElementById("geocodMsgG").innerHTML = "out of bounds";} } //refers to the second if(geocoding's status) else {document.getElementById("geocodMsgG").innerHTML = "error";} });//geocode }//major else (if address empty or not) }//function
Thank you...
