GIS Surface Analysis
F
FreeSmartGIS
Guest
فيديوهات شرح منظومة سمارت جى اى اس Smart GIS Tutorials Videos
A) Downloading (ASTER and SRTM) NASA Geo DEM Height Files
Open your Internet browser and go to the following URL to Download ASTER Geo DEM
http://www.gdem.aster.ersdac.or.jp/search.jsp
Open your Internet browser and go to the following URL to Download SRTM height files
http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/
B) Convert (ASTER and SRTM) NASA Geo DEM Height Files to Tin Shape File
Convert (ASTER & SRTM) DEM to Tin Shape file
Menu Tools Convert (ASTER & SRTM) DEM to Tin Shape file
C) Convert ASTER NASA Geo DEM to Color value bmp File
Convert ASTER Geo DEM to Color Value bmp file
Menu Layers Add Layer Files of Type TIFF Open
Menu
Layers Save Layer as Change the File extension to BMP Save
  • Open Aster Geo DEM Tiff file
  • Save Layer as bmp file
  • Press Identify at any point in image to get Elevation value
D) Building Contours from ASTER NASA Geo DEM
Menu Surface Building Contours Surface(s) Analysis
E) Building Tin Surface Analysis
Menu Surface Building Tin Surface(s) Analysis
  • Select Height Layer Name
  • Select Height Criteria (All Feature or Inside Selected Features or Outside Selected Features)
  • Select Height Field
  • Select Output Tin Surface Shape file name
  • Select Build Surface by Delaunay, if elevation points have unequal distances among them.
  • Select Build Surface by Matrix, if elevation points have equal distances among them.
  • Press Build
F) Building Contours Surface(s) Analysis
  • Check Use Height Layer as Tin Surface or Not
  • Select Contour Interval
  • Select Base Contour
  • Select Output Contour Shape file name
  • Select Do not build Surface, if Height layer is a Tin Surface
  • Press Build
G) Converting 2D to 3D Surface Analysis
Menu Surface Converting 2D to 3D Surface Analysis
  • Select Destination 2D GIS Shape File
  • Select Criteria of the Destination 2D GIS Shape File
  • Select Output 3D Shape file name
  • Press Convert
H) Calculating Area and Volume of Surface(s)
Calculate Area and Volume of Surface(s)
Menu Surface Calculate Area and Volume of Surface(s)
  • Select Height of the Calculating Plane
  • Select above Plane or Below Plane
  • Press Calculate
تسجيل منظومة سمارت جى اى اس ايتيدا Smart GIS Registeration in ITIDA
https://login.itida.gov.eg/ViewProfileFull.aspx?ID=2814
شهادات منظومة سمارت جى اى اس Smart GIS Certificates
https://drive.google.com/folderview...Z6SXJuOUdfdFp6amMyQURHSlYxZUoyR0U&usp=sharing
