JavaScript is run in a browser. It manipulates the behavior of your web-based content.
HTML, CSS and JavaScript all work together to create dynamic web content.
Again, the assumption is starting at zero. These 3 courses deliver a good base in JavaScript:
Create your own personal web map project by starting simple. Take latitude and longitude coordinates and put them on a web map with Leaflet, ESRI API or D3.
You’ve gone through the necessary courses. You’ve put your knowledge to action. It’s time to give your resume a boost and tell employers. At this stage, it wouldn’t be unreasonable to add “working knowledge of HTML, CSS, JS” upon completion.
000 00000000000
-- ADD YOUR CONTENT HERE --
- Introduction to JavaScript (KhanAcademy) – The KhanAcademy courses are very introductory and won’t take you very long to complete. This one starts with the basics and ends with object-oriented design. (Introduction to JavaScript)
- Javascript Basics (Udacity) – Udacity courses will help expand on the info learned above. Most introductory classes, but helps you to dive deeper into whatever direction you would like. (Javascript Basics)
- HTML/JS: Making Webpages Interactive (KhanAcademy) – This tells you how to include JavaScript libraries on your webpage, so that you can use functionality built by other web developers.(HTML/JS: Making Webpages Interactive)
000 00000000000
