GIS Buffers Are Not Overlapping correctly
I have two records in one GIS shapefile that I am trying to create two separate buffers around. When I go to Geoprocessing - Buffer I choose the desired shapefile, set the desired buffer distance, make the Side Type Full, End Type Round, and Dissolve Type None. When I run this the first buffer will be an oval as seen in the image, but the second buffer is a weird shape. How can I make both buffers be an oval?
Thank you in advance.
