GIS Analysis and Selection
F
FreeSmartGIS
Guest
فيديوهات شرح منظومة سمارت جى اى اس Smart GIS Tutorials Videos
A) Spatial Location Analysis and Selection
Selection Find and Data Transfer By Location (Query Builder)
Menu Selection Find and Data Transfer By Location (Query Builder)
  • Select Layer Name
  • Select Criteria (All Feature or Inside Selected Features or Outside Selected Features)
  • Select Method (New Selection or Add to Selection or Clear from Selection)
  • Select Relation
  • Select Relation to Layer
  • Select Apply Tolerance or not
  • Select Tolerance value
  • Select Apply Data Transfer for Similar Fields Name or not
  • Select Data Transfer Fields Names
  • Press Find to Start Searching
B) Attribute Data Base Analysis and Selection
Selection Find By Data (Query Builder)
Menu Selection Find By Data (Query Builder)
  • Select Layer Name
  • Select Field from the Fields List
  • Select Relation from the Relation List
  • Press Update Unique Value to get all available values
  • Select Value from the List or write it
  • Select Match Case or not
  • Select Map Scale for viewing result
  • Press Find to Start Searching the selected value
C) Nested Attribute Data Base Analysis and Selection
Nested Selection Find By Data (Query Builder)
Menu Selection Nested Find By Data (Query Builder)
  • Select Layer Name
  • Select Fields from the Fields Lists
  • Select Values
  • Press Find to Start Searching the selected values
D) Spatial Features Snapping and Dividing
Network Snap Vertexes to
Menu Network Snap Vertexes to
Menu
Network Divide Polylines or Polygon on
  • Select Layer Name
  • Select Vertexes (All , OR (Begin & End) )
  • Select Relation
E) Shortest Path Analysis
Building Shortest Path Network
Menu Network Build Shortest Path Network
Menu Network Shortest Path Network
  • Select Layer Name
  • Select Field Name
  • Press From Button
  • Select on the map where to start
  • Press To Button
  • Select on the Map where to Go
  • Press Run
تسجيل منظومة سمارت جى اى اس ايتيدا Smart GIS Registeration in ITIDA
https://login.itida.gov.eg/ViewProfileFull.aspx?ID=2814
شهادات منظومة سمارت جى اى اس Smart GIS Certificates
https://drive.google.com/folderview...Z6SXJuOUdfdFp6amMyQURHSlYxZUoyR0U&usp=sharing
