In my script I am using the Select tool (arcpy.Select_analysis) and in the SQL expression, I want to use a number that I call in as a parameter. I have trying to script it like:
subsize = arcpy.GetParameter(3)where_clause = '\"AreaSqKm\" > {0}'.format(subsize)arcpy.Select_analysis(waterbodies, lg_waterbodies, where_clause)In this example I'm entering the parameter as the number 0.0005, as a double.
I've tried tweaking it various ways, but every time I try to run the tool I get:ExecuteError: ERROR 000358" Invalid expression "AreaSqKm > 0.0005 Failed to execute (Select).
If i hard code that variable in a script as 0.0005 and run it as a stand alone it works fine. Any ideas on why it won't run in arc?
