I need to get a value from an IObject.Fields.Field using ArcObjects 10.x using the criteria listed below:
- If the field has a subtype associated with it, I need to get thesubtype name/description based on the field value.
- If the field has a coded value domain associated with it, I need toget the domain's name/description based on the field value.
- If the field has neither a subtype or domain associated with it, Iwant the field value itself returned.
- Having this functionality wrapped up in one call like "ReadFieldValue(IObject obj, int fieldIndex) is preferred.
