I have got a leaflet map with Geojson layers :
I use jquery Autocomplete to search an entity by name or id, I have no problem with that. I need your help because I'm not able to refer to a specific point in my layer (without a click on the map). Ideally, I would zoom in on it and open a popup.
Here is my code for loading Geojson markers :
var markers = L.markerClusterGroup({showCoverageOnHover: false,disableClusteringAtZoom: 9}); var points_rand = L.geoJson(points, { onEachFeature: function (feature, layer) //functionality on click on feature { //ARRAY FOR AUTOCOMPLETE musees_names_array.push(feature.properties.nom_musee, feature.properties.id); //ARRAY KEY VALUE musees_key_value[feature.properties.nom_musee] = feature.properties.id; { var title_ = ""+feature.properties.nom_musee+"
"; var subtitle = ""; var ouverture = ""; if(feature.properties.site_web != null ){ subtitle +="Site web : " +""+feature.properties.site_web+"</br>"; } if(feature.properties.periode_ouverture != null ){ subtitle +="Horaires : " +" "+feature.properties.periode_ouverture+"
</br>"; } } layer.bindPopup( title_ + subtitle + ouverture ) layer.setIcon(IconPerso); } });After a research with Autocomplete I have a function with the id selected but I don't know how zoom on a specific marker :
$(function() {$("#search_musee").autocomplete( { source:musees_names_array, minLength: 3, select: function( event, ui ) { var id_musee = musees_key_value[ui.item.value];// ID selected //HERE IS MY PROBLEM //I would like something like : // map.fitBounds(SPECIFIC_MARKER.getBounds()); } })});
I did some research like trigger event leaflet but without success,
Thanks in advance for help,
