I did an implementation similar to http://openlayers.org/dev/examples/sundials.htmlThe difference is that I have two or more kml layers at the same location and want to show their information combined.
The problem is that the featureselected layer's event fires only once, for the top most kml layer.
Does anyone know how to get this working, or a possible workarround?
Here is my code:
function createFetureInfoService() {var wmsServerArray = [];var dictionary = {};var items = [];var location;for (var i = 0; i < wmsControls.length; i++) { wmsControls.deactivate();}for (var i = 0; i < kmlControls.length; i++) { mapa.removeControl(kmlControls); kmlControls.deactivate();}kmlControls.length = 0;wmsControls.length = 0;totalWMSServerCount = 0;currentWMSServerCount = 0;totalKMLCount = 0;currentKMLCount = 0;for (var i = 0; i < mapa.getNumLayers(); i++) { layer = mapa.layers; if ((layer instanceof OpenLayers.Layer.WMS) && !layer.isBaseLayer) { if (!dictionary.hasOwnProperty(layer.url)) { totalWMSServerCount++; wmsServerArray.push(layer.url); dictionary[layer.url] = ""; } } else if ((layer instanceof OpenLayers.Layer.Vector) && (layer.hasOwnProperty("options")) && (layer.options.hasOwnProperty("protocol")) && (layer.options.protocol.hasOwnProperty("format")) && (layer.options.protocol.format instanceof OpenLayers.Format.KML) && !layer.isBaseLayer) { layer.displayOutsideMaxExtent = true; select = new OpenLayers.Control.SelectFeature(layer); kmlControls.push(select); layer.events.on({ featureselected: function (e) { var feature = e.feature; location = e.xy; items.push({ xtype: "propertygrid", autoHeight: true, title: feature.layer.name, source: feature.attributes }); currentKMLCount++; showGetFeaturePopup(items, location); feature.layer.selectedFeatures.length = 0; } }); mapa.addControl(select); select.activate(); }}for (var i = 0; i < wmsServerArray.length; i++) { var wmsFeatureInfo = new OpenLayers.Control.WMSGetFeatureInfo({ url: wmsServerArray, map: mapa, infoFormat: "application/vnd.ogc.gml" }); wmsControls.push(wmsFeatureInfo); wmsFeatureInfo.events.on({ getfeatureinfo: function (e) { location = e.xy; Ext.each(e.features, function (feature) { items.push({ xtype: "propertygrid", autoHeight: true, title: feature.fid, source: feature.attributes }); }); currentWMSServerCount++; showGetFeaturePopup(items, location); }, beforegetfeatureinfo: function (e) { this.layers = filterQueryableLayers(this.url); }, nogetfeatureinfo: function (e) { currentWMSServerCount++; showGetFeaturePopup(items, location); } }); wmsFeatureInfo.activate();} }
function showGetFeaturePopup(items, location) {totalKMLCount = 0;var layers = mapa.getLayersBy("visibility", true); for (var i = 0, len = layers.length; i < len; i++) { if ((layers instanceof OpenLayers.Layer.Vector) && (layers.hasOwnProperty("options")) && (layers.options.hasOwnProperty("protocol")) && (layers.options.protocol.hasOwnProperty("format")) && (layers.options.protocol.format instanceof OpenLayers.Format.KML) && !layers.isBaseLayer) { totalKMLCount++; }}if ((currentWMSServerCount + currentKMLCount) < (totalWMSServerCount + totalKMLCount)) return;currentWMSServerCount = 0;currentKMLCount = 0;if (items.length == 0) showInfoPopup(mapa.getLonLatFromPixel(location), 'Nenhuma informa\u00E7\u00E3o dispon\u00EDvel');else { var popUp = new GeoExt.Popup({ title: "Informa\u00E7\u00E3o sobre as Camadas WMS", layout: "accordion", anchored: false, resizable: true, map: mapa, location: location, items: items, autoScroll: true, width: 600, height: 600, unpinnable: false, draggable: true, closeAction: 'hide' }); popUp.show();}items.length = 0;}
Here is my code:
