Get ClosestPoint between geometry(Point) and geometry(multilinestring)
I think my question is rather simple, but being new to PostGIS, I can't figure it out myself nor being able to transfer knowledge of other questions to my issue.
The problem: I have two tables (testme, roads) with points as geometries (b.geom2 intestme --> point; a.geom in roads --> multistring) in my PostgreSQL-database. Now I am trying to find for every point in testme the closest point in roads.
Alter TABLE testme Add Column matched_geom geometry(Point,4326); Select a.geom, b.geom2, ST_Closestpoint(b.geom2, a.geom) as the_geom from roads as a, testme as b The result of the query should be to append the closest point found (for every point/row in testme according to roads) in a new column called matched_geom in the table testme...
