Geoserver wont start
Im using Geoserver 2.7.1 on a linux OS.Everything was working well until i try to put a crossdomail.xml file next to my geoserver.war to allow the acces to my WMS. After just puting the file i tried to restart tomcat, but the war is not deploying well. I try to delete the file and restart tomcat after deleting, and again geoserver is not deploying well, the deployement stop everytime at the line "WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset."
The log:
Dec 22, 2015 12:11:50 PM org.apache.coyote.AbstractProtocol initINFO: Initializing ProtocolHandler ["ajp-bio-8012"]Dec 22, 2015 12:11:50 PM org.apache.catalina.startup.Catalina loadINFO: Initialization processed in 669 msDec 22, 2015 12:11:50 PM org.apache.catalina.core.StandardService startInternalINFO: Starting service CatalinaDec 22, 2015 12:11:50 PM org.apache.catalina.core.StandardEngine startInternalINFO: Starting Servlet Engine: Apache Tomcat/7.0.52Dec 22, 2015 12:11:50 PM org.apache.catalina.startup.HostConfig deployWARINFO: Deploying web application archive /appli/projects/IDS/tomcat_7.0.52/geoserver/webapps/geoserver.warDec 22, 2015 12:12:15 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDALINFO: GDAL Native Library loaded (version: 1.9.2)Dec 22, 2015 12:12:15 PM it.geosolutions.util.KakaduUtilities loadKakaduWARNING: Failed to load the Kakadu native libs. This is not a problem unless you need to use the Kakadu plugin: it won't be enabled. java.lang.UnsatisfiedLinkError: no kdu_jni in java.library.pathDec 22, 2015 12:12:15 PM it.geosolutions.imageio.plugins.turbojpeg.TurboJpegUtilities loadTurboJpegWARNING: Failed to load the TurboJpeg native libs. This is not a problem, but the TurboJpeg encoder won't be available: java.lang.UnsatisfiedLinkError: no turbojpeg in java.library.pathDec 22, 2015 12:12:16 PM org.geoserver.platform.GeoServerExtensions checkContextWARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.log4j:WARN File option not set for appender [geoserverlogfile].log4j:WARN Are you using FileAppender instead of ConsoleAppender?Dec 22, 2015 12:12:19 PM org.geoserver.platform.GeoServerExtensions checkContextWARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Any comment is welcome!
