Geoserver Seed Problem ( die after submit )
I'm having a problem with seed/truncate on geoserver...I have a custum gridset "EPSG:900913" but with just the first 20 zoom levels...And i have some layer's (30) and some MrSid's (160) with this cache options:
The Problem is, when a try to seed:
I get this:
2015-11-23 11:07:09,338 INFO [seed.SeedTask] - GWC Seeder Thread-13 begins seeding layer : p:Saneamento_ETAR2015-11-23 11:07:09,340 INFO [geoserver.wms] - Request: getServiceInfo2015-11-23 11:07:09,364 INFO [geoserver.wms] - Request: getMap Width = 256 Height = 512 StyleBody = null SldVersion = null StyleVersion = null ScaleMethod = null Exceptions = SE_XML Tiled = false Palette = null FeatureVersion = null SRS = EPSG:900913 Styles = [StyleImpl[ name=p_Saneamento_ETAR]] Layers = [org.geoserver.wms.MapLayerInfo@a9b8a7a1] MaxFeatures = null Crs = PROJCS["WGS84 / Google Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH], AUTHORITY["EPSG","4326"]], PROJECTION["Mercator_1SP"], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","900913"]] Bbox = SRSEnvelope[-2.003750834E7 : 0.0, -2.003750834E7 : 2.003750834E7] RemoteOwsType = null RemoteOwsURL = null Env = {} FormatOptions = {} Angle = 0.0 CQLFilter = null Elevation = [] FeatureId = null StartIndex = null ViewParams = null BgColor = java.awt.Color[r=255,g=255,b=255] Transparent = true StyleFormat = sld SldBody = null ValidateSchema = false Sld = null StyleUrl = null TilesOrigin = null Interpolations = [] Format = image/png Buffer = 0 Time = [] Filter = null Filters = null Get = true RequestCharset = UTF-8 RawKvp = {BBOX=-20037508.34,-20037508.34,0.0,20037508.34, SERVICE=WMS, HEIGHT=512, REQUEST=GetMap, STYLES=p_Saneamento_ETAR, WIDTH=256, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1, FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=p:Saneamento_ETAR, SRS=EPSG:900913} BaseUrl = http://localhost:8080/geoserver/ Version = 1.1.1 Request = GetMap2015-11-23 11:07:09,370 INFO [geoserver.wms] - Request: getServiceInfo2015-11-23 11:07:10,940 INFO [geoserver.wms] - Request: getMap Width = 512 Height = 768 StyleBody = null SldVersion = null StyleVersion = null ScaleMethod = null Exceptions = SE_XML Tiled = false Palette = null FeatureVersion = null SRS = EPSG:900913 Styles = [StyleImpl[ name=p_Saneamento_ETAR]] Layers = [org.geoserver.wms.MapLayerInfo@a9b8a7a1] MaxFeatures = null Crs = PROJCS["WGS84 / Google Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH], AUTHORITY["EPSG","4326"]], PROJECTION["Mercator_1SP"], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","900913"]] Bbox = SRSEnvelope[-2.003750834E7 : 0.0, -2.003750834E7 : 1.0018754169999998E7] RemoteOwsType = null RemoteOwsURL = null Env = {} FormatOptions = {} Angle = 0.0 CQLFilter = null Elevation = [] FeatureId = null StartIndex = null ViewParams = null BgColor = java.awt.Color[r=255,g=255,b=255] Transparent = true StyleFormat = sld SldBody = null ValidateSchema = false Sld = null StyleUrl = null TilesOrigin = null Interpolations = [] Format = image/png Buffer = 0 Time = [] Filter = null Filters = null Get = true RequestCharset = UTF-8 RawKvp = {BBOX=-20037508.34,-20037508.34,0.0,10018754.169999998, SERVICE=WMS, HEIGHT=768, REQUEST=GetMap, STYLES=p_Saneamento_ETAR, WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1, FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=p:Saneamento_ETAR, SRS=EPSG:900913} BaseUrl = http://localhost:8080/geoserver/ Version = 1.1.1 Request = GetMap2015-11-23 11:07:11,373 INFO [geoserver.wms] - Request: getServiceInfo2015-11-23 11:07:12,321 ERROR [geoserver.ows] - java.lang.OutOfMemoryError: Java heap space2015-11-23 11:07:12,322 INFO [seed.GWCTask] - Thread group finished SEED task after 2.984 seconds2015-11-23 11:07:12,322 ERROR [seed.MTSeeder] - Problem communicating with GeoServerorg.geowebcache.GeoWebCacheException: Problem communicating with GeoServer at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:575) at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:764) at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:136) at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76) at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36) at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745)Caused by: java.lang.IllegalStateException: Expected: RenderedImageMap, got null at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:628) at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:569) ... 9 more2015-11-23 11:07:26,291 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaksWhat can i do?
Thanks a lot
