We have a geoserver 2.7.1 running as a war on tomcat7 in a Ubuntu 14.04 box. When asking for a WMS we get a java.lang.NullPointerException, but only when the map window is above certain size and only on a specific Geoserver layer.
A request like this works fine:
http://192.168.11.50:8080/geoserver...20875346,241044.61657051594,5070331.734186896
A request like this also works fine:
http://192.168.11.50:8080/geoserver...76768157,241035.47249242518,5070322.366172199
But this request brings back an xml with a nullPointerException:
http://192.168.11.50:8080/geoserver...180186812,241018.15472820433,5070300.94290353
This layer is using a transformation style to produce a Heatmap. That, and the fact that only changing the size of the image requested makes it crash, would make me think about memory issues. But I have upped the max rendering memory of the WMS in Geoserver to 1048576 with the same results.
Also, if I ask for a tiled image I get no error, but the tiling of a heatmap layer does not produce good results.
Any ideas on how to fix this?
The geoserver log of the failing request says:
2015-10-15 10:09:06,299 INFO [geoserver.wms] - Request: getServiceInfo2015-10-15 10:09:07,100 INFO [geoserver.wms] - Request: getMap Width = 1772 Height = 1762 MaxFeatures = null Crs = PROJCS["WGS 84 / Pseudo-Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH], AUTHORITY["EPSG","4326"]], PROJECTION["Popular Visualisation Pseudo Mercator", AUTHORITY["EPSG","1024"]], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH], AUTHORITY["EPSG","3857"]] Bbox = SRSEnvelope[240952.01878380912 : 241018.15472820433, 5070235.180186812 : 5070300.94290353] RemoteOwsType = null RemoteOwsURL = null Env = {} FormatOptions = {} Angle = 0.0 CQLFilter = [[ floor = 35 ]] Elevation = [] FeatureId = null StartIndex = null ViewParams = null Layers = [org.geoserver.wms.MapLayerInfo@be6cfff] Tiled = false Palette = null SRS = EPSG:3857 FeatureVersion = null Styles = [StyleImpl[ name=heatmap]] BgColor = java.awt.Color[r=255,g=255,b=255] Transparent = true StyleFormat = sld SldBody = null ValidateSchema = false Sld = null StyleUrl = null TilesOrigin = null Interpolations = [] Exceptions = SE_XML StyleBody = null SldVersion = null StyleVersion = null ScaleMethod = null Buffer = 0 Time = [[Wed Jul 16 18:00:00 CEST 2014, Sun Jul 17 01:59:59 CEST 2016]] Filter = [[ floor = 35 ]] Format = image/png Filters = [[ floor = 35 ]] Get = true RawKvp = {TIME=2014-07-16T16:00:00.000Z/2016-07-16, BBOX=240952.01878380912,5070235.180186812,241018.15472820433,5070300.94290353, SERVICE=WMS, TILED=false, HEIGHT=1762, REQUEST=GetMap, STYLES=, WIDTH=1772, CQL_FILTER=floor=35, TRANSPARENT=true, VERSION=1.1.1, FORMAT=image/png, LAYERS=openrtls
resence, SRS=EPSG:3857} BaseUrl = http://192.168.11.50:8080/geoserver/ RequestCharset = UTF-8 Version = 1.1.1 Request = GetMap2015-10-15 10:09:10,507 ERROR [geoserver.ows] - java.lang.NullPointerException at com.sun.media.jai.util.SunCachedTile.(SunCachedTile.java:80) at com.sun.media.jai.util.SunTileCache.add(SunTileCache.java:257) at javax.media.jai.OpImage.addTileToCache(OpImage.java:1087) at javax.media.jai.OpImage.getTile(OpImage.java:1142) at javax.media.jai.PlanarImage.getData(PlanarImage.java:2085) at javax.media.jai.PlanarImage.getData(PlanarImage.java:2016) at javax.media.jai.RenderedOp.getData(RenderedOp.java:2266) at it.geosolutions.imageio.plugins.png.ScanlineProviderFactory.getProvider(ScanlineProviderFactory.java:53) at it.geosolutions.imageio.plugins.png.PNGWriter.isScanlineSupported(PNGWriter.java:111) at org.geoserver.wms.map.png.PNGJWriter.writePNG(PNGJWriter.java:42) at org.geoserver.wms.map.PNGMapResponse.formatImageOutputStream(PNGMapResponse.java:109) at org.geoserver.wms.map.RenderedImageMapResponse.write(RenderedImageMapResponse.java:123) at org.geoserver.ows.Dispatcher.response(Dispatcher.java:990) at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:284) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778) at javax.servlet.http.HttpServlet.service(HttpServlet.java:620) at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75) at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87) at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173) at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745)
