I've installed OpenGeo 3.1 and I want to do some changes in config.yaml.The thing is that after certain changes like changing font color or adding font type it cause the print provider to crush.
for example :
In A4:
- !text text: "${mapTitle}" fontSize: 30 spacingAfter: 30 align: centerif I add font: Helvetica or add fontColor:black I get error from
http://localhost:8080/geoserver/pdf/info.json
This makes me think that the printing provider i'm using doesn't support these configurations
I've checked in geoserver , These 2 jars are installed :
printing-2.2-SNAPSHOT.jarprint-lib-1.2-20101018133712.jarWhat am I missing here ?!
HTTP ERROR: 500org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.ho.yaml.exception.YamlException: Error near line 0: End of document expected.RequestURI=/geoserver/pdf/info.jsonCaused by:java.lang.RuntimeException: org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.ho.yaml.exception.YamlException: Error near line 0: End of document expected. at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:177) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilterThis is the originl config.yaml :
dpis: [75, 150, 300]scales: - 524288000 - 262144000 - 131072000 - 65536000 - 32768000 - 16384000 - 8192000 - 4096000 - 2048000 - 1024000 - 512000 - 256000 - 128000 - 64000 - 32000 - 16000 - 8000 - 4000 - 2000 - 1000hosts: - !localMatch dummy: true - !ipMatch ip: 0.0.0.0 mask: 0.0.0.0layouts: A4: metaData: &commonMetaData title: "${mapTitle}" author: "GeoExplorer" subject: "Map printed with the OpenGeo Suite" keywords: "map,print" creator: "OpenGeo Suite" mainPage: pageSize: A4 rotation: true items: - !text text: "${mapTitle}" fontSize: 30 spacingAfter: 30 align: center - !map spacingAfter: 10 width: 440 height: 600 - !scalebar type: bar maxSize: 100 barBgColor: white fontSize: 8 align: right spacingAfter: 10 - !text text: "${comment}" Legal: metaData: *commonMetaData mainPage: pageSize: LEGAL rotation: true items: - !text text: "${mapTitle}" fontSize: 30 spacingAfter: 30 align: center - !map spacingAfter: 10 width: 440 height: 650 - !scalebar type: bar maxSize: 100 barBgColor: white fontSize: 8 align: right spacingAfter: 10 - !text text: "${comment}" Letter: metaData: *commonMetaData mainPage: pageSize: LETTER rotation: true items: - !text text: "${mapTitle}" fontSize: 30 spacingAfter: 30 align: center - !map spacingAfter: 10 width: 440 height: 550 - !scalebar type: bar maxSize: 100 barBgColor: white fontSize: 8 align: right spacingAfter: 10 - !text text: "${comment}"
for example :
In A4:
