Geoserver + Mongodb connection OK , but not showing layers
I have followed the discussion on : Geoserver + MongoDB: connection OK but layers list empty ->
"The connection between Geoserver and MongoDB is OK and when I create a new datastore in geoserver->stores->Add new Store, it creates the database on mongo as expected. The problem is that, if I go in layers->Add a new resource and select the correct resource, the layer's list remain empty. On the top i see only "You can create a new feature type by manually configuring the attribute names and types. Create new feature type..."
I tried the solution suggested but could not get through it.Can somebody please suggest a step-wise procedure to do it.
Thanks in advance.
