I setted up Geoserver (ver. 2.5.2) with the MongoDB plugin (ver. 11.2 - http://repo.opengeo.org/org/geotools/gt-mongodb/11.2/). The connection between Geoserver and MongoDB is OK and when I create a new datastore in geoserver->stores->Add new Store, it creates the database on mongo as expected. The problem is that, if I go in layers->Add a new resource and select the correct resource, the layer's list remain empty. On the top i see only "You can create a new feature type by manually configuring the attribute names and types. Create new feature type..." but i cannot find documentation on how to use that.
Any help?Thanks in advance
EDIT: in the goserver's log i've just found this error:
ERROR [data.mongodb] - getLayers error; command failed [mapreduce]: { "serverUsed" : "[iport]" , "errmsg" : "exception: ReferenceError: mapfields_recursive is not defined near 'ction() { mapfields_recursive (\"\", this);' " , "code" : 16722 , "ok" : 0.0} but I can't still figure out what is the problem and how to solve it.Any ideas?
