Geoserver MBTiles plugins performance issues
I am using the latest stable 2.7.2 version of GeoServer and I am trying to play with the MBTiles plugin, I have installed also WPS plugin that is needed by the MBTiles one (otherwise I got error when starting). I am using the MBTiles plugin found on community-latest because no one is found under the release folder for 2.7.2 version, however it seems to work, the only problem is that is really bad in performance (30-40s or even more for each request to be displayed). Reading MBTiles under OpenMap (BBN Technologies) or under World Wind Java (I have wrote a plugin for that) is really fast and straight forward, I don't understand why it is so slow. Could be probably something related to different projection system? My MBTiles is in EPSG 3857, but requested display projection is the same, so I suppose that no re-projection is needed....Prior to investigate on the GeoServer code for the MBTiles plugin, I would ask you if someone has experienced the same performance problem.
Taking a thread stack I see that Geoserver seems always executing this piece of code:
at org.sqlite.jdbc3.JDBC3PreparedStatement.executeQuery(JDBC3PreparedStatement.java:68)at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)at org.geotools.mbtiles.MBTilesFile.closestZoom(MBTilesFile.java:519)at org.geotools.mbtiles.mosaic.MBTilesReader.read(MBTilesReader.java:152)at org.geotools.coverage.grid.io.AbstractGridCoverage2DReader.read(AbstractGridCoverage2DReader.java:249)at org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:147)at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:227)at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:217)
