GeoServer failed to start on an Amazon EC2 instance
I am trying to get GeoServer up and running on an Amazon EC2 instance but it does not work. I am using Java 8 (Oracle) and Tomcat 8.0.24. The thing is I have got the same stack up and running on a local VM but does not work on the EC2. Any help would be appreciated. Here is the Tomcat log:
24-Jul-2015 04:06:12.027 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.2424-Jul-2015 04:06:12.029 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jul 1 2015 20:19:55 UTC24-Jul-2015 04:06:12.029 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.24.024-Jul-2015 04:06:12.029 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux24-Jul-2015 04:06:12.029 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 3.13.0-48-generic24-Jul-2015 04:06:12.029 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd6424-Jul-2015 04:06:12.030 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /usr/lib/jvm/java-8-oracle/jre24-Jul-2015 04:06:12.030 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_45-b1424-Jul-2015 04:06:12.030 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation24-Jul-2015 04:06:12.031 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /var/local/tomcat824-Jul-2015 04:06:12.031 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /var/local/tomcat824-Jul-2015 04:06:12.031 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/var/local/tomcat8/conf/logging.properties24-Jul-2015 04:06:12.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager24-Jul-2015 04:06:12.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=/var/local/tomcat8/endorsed24-Jul-2015 04:06:12.038 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/var/local/tomcat824-Jul-2015 04:06:12.039 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/var/local/tomcat824-Jul-2015 04:06:12.039 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/var/local/tomcat8/temp24-Jul-2015 04:06:12.039 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib24-Jul-2015 04:06:12.269 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]24-Jul-2015 04:06:12.294 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read24-Jul-2015 04:06:12.299 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]24-Jul-2015 04:06:12.300 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read24-Jul-2015 04:06:12.305 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 947 ms24-Jul-2015 04:06:12.348 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina24-Jul-2015 04:06:12.350 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.2424-Jul-2015 04:06:12.394 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive /var/local/tomcat8/webapps/geoserver.war24-Jul-2015 04:06:18.477 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.24-Jul-2015 04:06:19.315 WARNING [localhost-startStop-1] null.null Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.24-Jul-2015 04:06:20.972 WARNING [localhost-startStop-1] null.null Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.24-Jul-2015 04:06:27.169 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file24-Jul-2015 04:06:27.184 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/geoserver] startup failed due to previous errors24-Jul-2015 04:06:27.194 INFO [localhost-startStop-1] null.null Beginning GeoServer cleanup sequence24-Jul-2015 04:06:27.194 INFO [localhost-startStop-1] null.null Unregistered JDBC driver org.hsqldb.jdbc.JDBCDriver@2967ee6f24-Jul-2015 04:06:27.194 INFO [localhost-startStop-1] null.null Unregistered JDBC driver org.h2.Driver@7c9a7a3324-Jul-2015 04:06:27.194 INFO [localhost-startStop-1] null.null Unregistered JDBC driver org.postgresql.Driver@10560f5824-Jul-2015 04:06:27.214 INFO [localhost-startStop-1] null.null Disposing referencing factory GeoserverWKTOperationFactory["European Petroleum Survey Group"] COORDINATE_OPERATION_AUTHORITY_FACTORY = PropertyCoordinateOperationAuthorityFactory["European Petroleum Survey Group"] CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory 24-Jul-2015 04:06:27.216 INFO [localhost-startStop-1] null.null Disposing referencing factory LongitudeFirstFactory["European Petroleum Survey Group"] FORCE_LONGITUDE_FIRST_AXIS_ORDER = true FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false CS_AUTHORITY_FACTORY = OrderedAxisAuthorityFactory["European Petroleum Survey Group"] DATUM_AUTHORITY_FACTORY = ThreadedHsqlEpsgFactory["European Petroleum Survey Group"] EPSG_DATA_SOURCE = java:comp/env/jdbc/EPSG DATUM_AUTHORITY_FACTORY = FactoryUsingHSQL["European Petroleum Survey Group"] FORCE_LONGITUDE_FIRST_AXIS_ORDER = false FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false VERSION = 8.6 CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) FORCE_STANDARD_AXIS_UNITS = false FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_LONGITUDE_FIRST_AXIS_ORDER = true CRS_AUTHORITY_FACTORY = (same as CS_AUTHORITY_FACTORY) 24-Jul-2015 04:06:27.221 INFO [localhost-startStop-1] null.null Disposing referencing factory HTTP_AuthorityFactory["URL in OGC namespace"] DATUM_AUTHORITY_FACTORY = AllAuthoritiesFactory["All"] CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY)24-Jul-2015 04:06:27.339 INFO [localhost-startStop-1] null.null Disposing referencing factory GeoserverOverridingWKTFactory["European Petroleum Survey Group"] CRS_AUTHORITY_EXTRA_DIRECTORY = null DATUM_AUTHORITY_FACTORY = PropertyAuthorityFactory["European Petroleum Survey Group"] FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) 24-Jul-2015 04:06:27.342 INFO [localhost-startStop-1] null.null Disposing referencing factory LongitudeFirstFactory["European Petroleum Survey Group"] FORCE_LONGITUDE_FIRST_AXIS_ORDER = true FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false CS_AUTHORITY_FACTORY = OrderedAxisAuthorityFactory["European Petroleum Survey Group"] DATUM_AUTHORITY_FACTORY = ThreadedHsqlEpsgFactory["European Petroleum Survey Group"] EPSG_DATA_SOURCE = java:comp/env/jdbc/EPSG DATUM_AUTHORITY_FACTORY = FactoryUsingHSQL["European Petroleum Survey Group"] FORCE_LONGITUDE_FIRST_AXIS_ORDER = false FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false VERSION = 8.6 CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) FORCE_STANDARD_AXIS_UNITS = false FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_LONGITUDE_FIRST_AXIS_ORDER = true CRS_AUTHORITY_FACTORY = (same as CS_AUTHORITY_FACTORY) 24-Jul-2015 04:06:27.346 INFO [localhost-startStop-1] null.null Disposing referencing factory GeoserverCustomWKTFactory["European Petroleum Survey Group"] CRS_AUTHORITY_EXTRA_DIRECTORY = null DATUM_AUTHORITY_FACTORY = PropertyAuthorityFactory["European Petroleum Survey Group"] FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) 24-Jul-2015 04:06:27.354 INFO [localhost-startStop-1] null.null Disposing referencing factory CartesianAuthorityFactory["European Petroleum Survey Group"] CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory24-Jul-2015 04:06:27.354 INFO [localhost-startStop-1] null.null Disposing referencing factory HTTP_AuthorityFactory["URL in OGC namespace"] DATUM_AUTHORITY_FACTORY = AllAuthoritiesFactory["All"] CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY)24-Jul-2015 04:06:27.355 INFO [localhost-startStop-1] null.null Disposing referencing factory AutoCRSFactory["Automatic Projections"] CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory24-Jul-2015 04:06:27.355 INFO [localhost-startStop-1] null.null Disposing referencing factory WebCRSFactory["Web Map Service CRS"] CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory24-Jul-2015 04:06:27.445 INFO [localhost-startStop-1] null.null Disposing referencing factory LongitudeFirstFactory["European Petroleum Survey Group"] FORCE_LONGITUDE_FIRST_AXIS_ORDER = true FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false CS_AUTHORITY_FACTORY = OrderedAxisAuthorityFactory["European Petroleum Survey Group"] DATUM_AUTHORITY_FACTORY = ThreadedHsqlEpsgFactory["European Petroleum Survey Group"] EPSG_DATA_SOURCE = java:comp/env/jdbc/EPSG DATUM_AUTHORITY_FACTORY = FactoryUsingHSQL["European Petroleum Survey Group"] FORCE_LONGITUDE_FIRST_AXIS_ORDER = false FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_STANDARD_AXIS_UNITS = false VERSION = 8.6 CRS_FACTORY = ReferencingObjectFactory CS_FACTORY = (same as CRS_FACTORY) DATUM_FACTORY = DatumAliases MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) FORCE_STANDARD_AXIS_UNITS = false FORCE_STANDARD_AXIS_DIRECTIONS = false FORCE_LONGITUDE_FIRST_AXIS_ORDER = true CRS_AUTHORITY_FACTORY = (same as CS_AUTHORITY_FACTORY) 24-Jul-2015 04:06:27.453 INFO [localhost-startStop-1] null.null Disposing referencing factory HTTP_AuthorityFactory["URL in OGC namespace"] DATUM_AUTHORITY_FACTORY = AllAuthoritiesFactory["All"] CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY) COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY)24-Jul-2015 04:06:27.454 INFO [localhost-startStop-1] null.null Shut down GT referencing threads 24-Jul-2015 04:06:27.454 INFO [localhost-startStop-1] null.null Shut down GT SPI 24-Jul-2015 04:06:27.454 INFO [localhost-startStop-1] null.null Shut down coverage thread pool 24-Jul-2015 04:06:27.457 SEVERE [localhost-startStop-1] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [geoserver] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1673f12e]) and a value of type [org.springframework.security.core.context.SecurityContextImpl] (value [org.springframework.security.core.context.SecurityContextImpl@ffffffff: Null authentication]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.24-Jul-2015 04:06:27.471 WARNING [localhost-startStop-1] null.null Prefs file removed in background /root/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml24-Jul-2015 04:06:27.476 SEVERE [localhost-startStop-1] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [geoserver] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@81d0795]) and a value of type [org.geotools.referencing.operation.projection.TransverseMercator.Provider] (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.24-Jul-2015 04:06:27.486 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive /var/local/tomcat8/webapps/geoserver.war has finished in 15,092 ms24-Jul-2015 04:06:27.487 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /var/local/tomcat8/webapps/ROOT24-Jul-2015 04:06:27.557 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /var/local/tomcat8/webapps/ROOT has finished in 69 ms24-Jul-2015 04:06:27.557 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /var/local/tomcat8/webapps/target24-Jul-2015 04:06:27.583 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /var/local/tomcat8/webapps/target has finished in 26 ms24-Jul-2015 04:06:27.584 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /var/local/tomcat8/webapps/examples24-Jul-2015 04:06:27.820 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /var/local/tomcat8/webapps/examples has finished in 236 ms24-Jul-2015 04:06:27.820 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /var/local/tomcat8/webapps/host-manager24-Jul-2015 04:06:27.855 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /var/local/tomcat8/webapps/host-manager has finished in 35 ms24-Jul-2015 04:06:27.856 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /var/local/tomcat8/webapps/manager24-Jul-2015 04:06:27.884 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /var/local/tomcat8/webapps/manager has finished in 29 ms24-Jul-2015 04:06:27.885 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /var/local/tomcat8/webapps/docs24-Jul-2015 04:06:27.907 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /var/local/tomcat8/webapps/docs has finished in 22 ms24-Jul-2015 04:06:27.913 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]24-Jul-2015 04:06:27.924 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]24-Jul-2015 04:06:27.930 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 15624 ms
