I have a database table with a dynamic schema implemented via a JSON column named "properties".
Currently GeoServer doesn't recognize my JSON column.
Is there some way to make Geoserver recognize the column?
Or may be if it doesn't work with JSON, is there some way to make it work with HSTore?
I need the properties JSON column to be rendered in the properties of a WFS response, also I need to apply several dynamic CQL_FILTER to the "properties" column.
