Geoserver 2.7 - 'Bounding Box & Lat-Long Data' fetching problem from Oracle Locator d
I have installed Geoserver 2.7 & connected my Oracle (Locator) database with available 'gt-jdbc-oracle-13.2.jar' extension.
During layer publishing containing fields like 'Geometry', it failed to fetch 'Native & Lat- Long Bounding box' informations.
I have published the same data on Geoserver 2.7 - from Oracle (Locator) using 'Configure new SQL view...' but after data publishing the map rendering time is more than normal (my Lan speeed is 1.0 Gbps).
However, my previous instance of Geoserver 2.5 - Oracle (Locator) combination does the above mentioned task nicely & is perfect for my Web based Map.(Refer to the image below)
Kindly advice on how to publish data with geometry from Oracle (locator) database from Geoserver 2.7 environment...!
