Pretty weird problem with SpatiaLite used within QGIS (2.13) with the DB Manager.
I have 2 layers (result of the same algorithm) and I use this function to merge them in a new table:
CREATE TABLE new_layer AS SELECT * FROM lay1 UNION ALL SELECT * FROM lay2; The function works fine except for the fact that the new Geometry column is recognized as NUM Type and not as MULTILINESTRING (the 2 starting layers have a correct Geometry column type).
When I recover the geometry column, it is correctly recovered (so the layer is transformed into a geometric object) but still the Geometry column is a NUM type:
SELECT RecoverGeometryColumn('new_layer', 'Geometry', 3003, 'MULTILINESTRING', 'XY') I think that this misunderstanding of SL can cause future incoherence with spatial operations.
Some idea?
Am I missing something?
Some idea?
