Using Leaflet with GeoJSON, I would like to create a map with geometries, and with alphanumerical data associated to each item of the geometry. A map very similar to the easy sample at http://leafletjs.com/examples/geojson.html, with the names/values of each one the points/lines/polygons.
However, I found that, in every example I've seen, the alphanumerical data ('properties') and the geometrical data ('geometry') are within the same GeoJSON file. I mean, for each one of the items ('Features'), there are 'properties' and 'geometry' associated with the same 'id'.
I wondered if there was any possibility to separate 'properties' and 'geometry' in two different files, joining the features through their ID.
Thank you very much.
