Geographic distance from path distance calculation
Is there some way to calculate a geographic distance grid from a path distance output? I'm using arcmap 10.2 and the cost grid is based on land cover and elevation.
I can use path distance to calculate travel times to safety but would like to turn it around to calculate the speed necessary to evacuate to high ground before a hazard arrives at a known time. The geographic distance could be used to calculate travel speed.
Thanks, Nate Wood
