Geodatabase field data types
When you create feature classes and tables, you select a data type for each field. The available types include a variety of number types, text, date, binary large objects (BLOBs), or globally unique identifiers (GUIDs). Choosing the correct data type allows you to correctly store the data and will facilitate your analysis, data management, and business needs.
The data types explained in this topic include all the data types available when creating a feature class or table with ArcMap or ArcCatalog. If you store your data in an ArcSDE geodatabase or a personal geodatabase, the data types between ArcGIS and your database management system (DBMS) might not match directly. The types are matched to the closest data type available in the DBMS. This process is referred to as data type mapping. In this process, it is possible that the values will be stored in the DBMS as a different type, applying different criteria to the data attribute. To learn more about the data type mapping process with your database management system, see Data types in the DBMS.
Numbers
You can store numbers in one of four numeric data types:
  • Short integers
  • Long integers
  • Single-precision floating point numbers, often referred to as floats
  • Double-precision floating point numbers, commonly called doubles
In choosing the data type, first consider the need for whole numbers versus fractional numbers. If you just need to store whole numbers, such as 12 or 12,345,678, specify a short or long integer. If you need to store fractional numbers that have decimal places, such as 0.23 or 1234.5678, specify a float or a double.
Secondly, when choosing between a short or long integer, or between a float or double, choose the data type that takes up the least storage space required. This will not only minimize the amount of storage required but will also improve performance. If you need to store integers between -32,768 and 32,767 only, specify the short integer data type, because it takes up only 2 bytes, whereas the long integer data type takes up 4. If you need to store fractional numbers between -3.4E-38 and 1.2E38 only, specify the float data type, because it takes up 4 bytes, whereas the double data type takes up 8. The following table lists data types, their ranges, and storage requirements. The ranges listed are for file and personal geodatabases. Ranges differ slightly in ArcSDE geodatabases.
Data typeStorable rangeSize (Bytes)Applications
Short integer-32,768 to 32,7672Numeric values without fractional values within specific range; coded values
Long integer-2,147,483,648 to 2,147,483,6474Numeric values without fractional values within specific range
Single-precision floating-point number (float)approximately -3.4E38 to 1.2E384Numeric values with fractional values within specific range
Double-precision floating-point number (double)approximately -2.2E308 to 1.8E3088Numeric values with fractional values within specific range
If you're specifying numeric fields for a table in a file or personal geodatabase, you need only specify the data type. If you're specifying numeric fields for an ArcSDE geodatabase, you additionally specify the precision, which is the maximum length of the field, and scale, which is the maximum number of decimal places.
Specifying the precision and scale allows you to restrict the range of values and number formats a field can accept, giving you greater control. For example, if you specify a float with a precision of 4 and a scale of 2, the field will accept 12.34. If you try to enter 12.345 into the field, an error message would display, as this exceeds the maximum number of digits and decimal places allowed. On the other hand, if you specify a float with a precision of 5 and a scale of 3, the field would let you enter the 12.345.
Data types and their possible precision and scale values are listed in the following table. Use this table to help you choose data type, precision, and scale for ArcSDE geodatabases.
Data type in ArcGIS DesktopPrecision (field length)Scale (decimal places)
Short integer*1–4 (Oracle)
5 (DB2, Informix, SQL Server)
0
Long integer5–10 (Oracle)
6-9 (DB2, Informix, SQL Server)
0
Float1–61–6
Double7+0+
*The precision for short integers differs depending on the DBMS. Short integers with a precision of 4 in Oracle can store values up to 9,999. Short integers with a precision of 5 in SQL Server, DB2, and Informix can store values up to 32,767. There is no reason for you to specify a precision for short integers in ArcCatalog on any database except Oracle. There is no reason to specify a precision for long integers in ArcCatalog on SQL Server databases.
The following provides examples of number ranges and how you could store them in an ArcSDE geodatabase for Oracle.
RangeData typePrecision (field length)Scale (decimal places)
0 to 99Short integer20
-99 to 99*Short integer30
0 to 99,999Long integer50
-99,999 to 99,999*Long integer60
0.001 to 0.999Float43
1,000.00 to 9,999.99Float62
-123,456.78 to 0*Double92
0 to 1,234.56789Double95
*Negative numbers require additional precision to store the negative sign.
Computers can only store a limited number of digits, depending on the storage space being allocated. Fields of data type double in file, personal, and ArcSDE geodatabases can precisely store numbers that contain up to 15 digits only, because this is the longest number that can fit into 8 bytes of storage space. Numbers that have more digits than this are rounded and stored in a format similar to scientific notation, making them approximate numbers only. For example, if you enter the 20-digit number 12,345,678,901,234,567,890, it is rounded and stored as the 15-digit number 1.23456789012346E+19. The coded value at the end, E+19, defines the placement of the decimal point.
Floats in file and personal geodatabases can store precisely numbers that contain up to 6 digits only. For example, you could not store the number 123,456.7 precisely in a float field because this number contains more than six digits. You can enter the number into a float field in a file or personal geodatabase, but it will be rounded to 123,457, a number containing the permissible 6 digits. If you need to store this number precisely, you could store it in a double field. Float fields in ArcSDE geodatabases do not let you enter more digits than the precision for the field, so no rounding takes place.
Text
A text field represents a series of alphanumeric symbols. This can include street names, attribute properties, or other textual descriptions. An alternative to using repeating textual attributes is to establish a coded value. A textual description would be coded with a numeric value. For example, you might code road types with numeric values by assigning a 1 to paved improved roads, a 2 to gravel roads, and so on. This has the advantage of using less storage space in the geodatabase; however, the coded values must be understood by the data user. If you define your coded values in a coded value domain in the geodatabase and associate the domain with the integer field storing your codes, the geodatabase will display the textual description when the table is viewed in ArcMap or ArcCatalog.
Learn more about subtypes and attribute domains.
The characters used for text vary by language. To allow text to more easily convert between languages, ArcGIS uses Unicode to encode characters.
Learn more about Unicode character encoding
Dates
The date data type can store dates, times, or dates and times. The default format in which the information is presented is mm/dd/yyyy hh:mm:ss and a specification of AM or PM. When you enter date fields in the table, they will be converted to this format.
BLOBs
A BLOB is simply some data stored in the geodatabase as a long sequence of binary numbers. ArcGIS stores annotation and dimensions as BLOBs, and items such as images, multimedia, or bits of code can be stored in this type of field. You need to use a custom loader or viewer or a third-party application to load items into a BLOB field or view the contents of a BLOB field.
Object Identifiers
The ObjectID field is maintained by ArcGIS and guarantees a unique ID for each row in the table. When you look at a table or a layer's attribute table, you will usually see the ObjectID field listed under the aliases of OID or ObjectID for tables and FID for layers. Key functions, such as scrolling and displaying selection sets, depend on the presence of this field.
It should be noted that most ArcGIS Desktop functionality, such as using the identify tool, requires the ObjectID to be unique. Therefore, caution should be used when working directly with the database so that ObjectIDs are not duplicated. For example, when creating views with a one to many relationship there is the possibility that ObjectIDs will be duplicated. This will cause inconsistent behavior in ArcGIS Desktop functionality.
Global identifiers
Global ID and GUID data types store registry style strings consisting of 36 characters enclosed in curly brackets. These strings uniquely identify a feature or table row within a geodatabase and across geodatabases. This is how features are tracked in one-way and two-way geodatabase replication. Developers can use them in relationships or in any application requiring globally unique identifiers. In a relationship, if a Global ID field is the origin key, a GUID field must be the destination key. You can add Global IDs to a feature in ArcCatalog by right-clicking it and clicking Add Global IDs. The geodatabase will then maintain these values automatically. You can create the GUID field in ArcCatalog, but you must maintain its values.
Databases with a native GUID data type, such as personal geodatabases and ArcSDE geodatabases in Microsoft SQL Server, store Global ID and GUID values as 16 bytes. Databases without a native GUID data type store them as 38 bytes.
Some notes on Global IDs
  • GUID fields can be added using the Fields tab in ArcCatalog Properties or the Add Field command in the table window.
  • The Add Global ID command is available for stand-alone feature classes, tables, and attributed relationship classes. It cannot be executed on individual datasets in a feature datatset. It can only be run on the entire feature dataset.
  • The Add Global ID command is available for ArcSDE geodatabase connections only.
  • If a Global ID already exists, the command leaves the old column, it doesn't drop and add a new Global ID column.
  • If you add a feature class to a feature dataset and want to add a Global ID column to it, you need to run the Add Global ID command on the feature dataset. This will add a Global ID column to the new feature class and any feature classes that don't already have a Global ID column. Feature classes already with a Global ID column will remain unchanged.
Fields of type raster
Unlike a hyperlink that simply links a feature's field to an image, a field of type raster can actually store the raster data within or alongside the geodatabase. To learn more, see Raster datasets as attributes.
GeometryIn ArcGIS, the geometry data type indicates the type of geometry—point, line, polygon, multipoint, or multipatch—the table stores. The field stored as geometry type is usually called SHAPE.
Geometry is the data type used by ArcGIS. If you store your data in an ArcSDE geodatabase, how geometric data is stored in the DBMS depends on the DBMS type you are using. This is because ArcSDE for each supported DBMS uses specific geometry storage types.
For example, if you choose Polygon Features for a new feature class,
New polygon feature class
the SHAPE field added by default will have a data type of Geometry. In the Field Properties section of the New Feature Class dialog box, you will see the Geometry Type will be listed as Polygon.
geometry type
If you had created a feature class with a different feature type—line, point, multipoint, multipatch, dimension, or annotation—the geometry type for the SHAPE field would change accordingly—to line, point, multipoint, multipatch, or polygon for dimension and annotation.
For the DBMSs used with ArcSDE, how the value of the SHAPE field is stored in the DBMS depends on the geometry storage type used by the DBMS. So, if you create a new feature class in an ArcSDE Personal geodatabase, the values of the SHAPE field will be stored in the geometry storage type ArcSDE Compressed Binary.​
