Have you always wanted to start programming… but there was never a good time to start? This week we’ve got for you programming quiz for non-programmers. Check it out and have fun!
Remember to share your score with the world! And to check out our other*GeoawesomeQuizzes!
THE PROGRAMMING FOR NON-PRAGRAMMERS QUIZ
1. Which of the following is NOT a web language?
HTML
C++
JavaScript
PHP
Correct! Wrong!
2. What is the software called that translates code into something meaningful the computer can understand?
Converter
Translator
Transliterator
Compiler
Correct! Wrong!
3. Which of the following is NOT a software language?
C
C++
Visual Basic
HTML
Correct! Wrong!
4. What is the difference between a variable and a constant?
No difference
Variables can be declared only in software languages
The value of a constant doesn't change, the value of a variable can change all throughout a program
Constants can be declared only in Java
Correct! Wrong!
5. What is object-oriented programming?
A type of programming using only numbers
A type of programming involving data types representing data structures
A type of programming involving a structured method of creating programs
A type of programming not in use anymore
Correct! Wrong!
6. If you needed to execute some code repeatedly based on a certain condition, which of the following would you use?
Conditional
Variable
Loop
Compiler
Correct! Wrong!
Ask user for a number, ask user for another number, multiply the two numbers, print result..What do you call this set of instructions?
JavaScript
A class
A compiler
An algorithm
Correct! Wrong!
8. Which programming languages are case sensitive?
Java
Phython
C
Visual Basic
Correct! Wrong!
9. Checking a computer program for errors is called _____.
bugging
syntaxing
debugging
correcting
Correct! Wrong!
10. The process of writing the computer instructions is called _____.
compiling
syntaxing
coding
interpreting
Correct! Wrong!
Share the quiz to show your results !
Just tell us who you are to view your results !
Show my results >>
#GeoawesomeQuiz 23 - Programming Quiz for Non-Programmers You got out of 10 right!
Share your results :
Google+
DID YOU LIKE THE QUIZ?
SUBSCRIBE TO OUR WEEKLY NEWSLETTER
The post #GeoawesomeQuiz 23 – Programming for non-programmers appeared first on Geoawesomeness.
