gdalwarp UTM Zone 1 to WGS84 - fails to transform
I have a global dataset consisting of tiles in UTM projection that I want to mosaic and therefore need to reproject to a common projection.
Can I solve my reprojection error with options to gdalwarp or do I need to manipulate the input files?
Reprojection is done with gdalwarp and the following command:
gdalwarp -t_srs EPSG:4326 -of GTiff -co "COMPRESS=LZW" N01_50.TIF N01_50_wgs84.TIFTiles in UTM Zone01 produce the following error and the result is visibly distorted (spans around the globe in E-W direction). All other tiles work fine.
ERROR 1: Too many points (441 out of 441) failed to transform, unable to compute output bounds. Warning 1: Unable to compute source region for output window 6006,0,6007,340,Here is the output of gdalsrsinfo and the download link of the input file (7.2 Mb):
PROJCS["WGS 84 / UTM zone 1N",GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS 84",6378137,298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich",0], UNIT["degree",0.0174532925199433], AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-177],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["meters",1],AUTHORITY["EPSG","32601"]]
