As an example I have a BSB file from NOAA which is a navigational map. The map has a SRS of WGS84 and a Mercator projection.
I initially translate the file from BSB format to GTiff format using the following command:
gdal_translate -of GTiff 18554_1.kap noaa.tif
I can view this GTiff file using Paint Shop Pro quite fine. I then translate the file from GTiff format to VRT format using the following command:
gdal_translate -of vrt –expand rgba noaa.tif noaa.vrt
I then try to generate a tile matrix set using the following command:
gdal2tiles.py noaa.vrt tiles_folder
Where the map tiles are located in tiles_folder. If I try to open the openmaps.html or google.html, the map zoom in and out looks good. However, on tiles generator like MBTiles, I see tiles swap. See the image below. I am pulling my hair off to get the tiles to line up. I am guessing it is projection error. I am not understanding those projection types. It would great someone can explain it while finding the error. I am planning to use on a tiling airplane maps/charts app like this. By the way, on GDAL how do I specify the BSB (reference) file that is associated with KAP (data) file? I have seen cases where only one BSB file referred by multiple KAP files.
