GDAL tiling with a lot of MrSID files
I'm trying to generate tiles for a region with a surface of 85k km2. The data source are MrSID files (2734 files). I'm using gdal to achieve this task.
It works fine with a small subset of MrSID, but with all the source files it would take more years than I could live :).
My process for generating tiles is the following:
# create the mosaicgdalwarp -of GTiff -dstalpha -r cubic [MrSID Files] mosaic.tiff`# generate tiles from mosaicgdal2tiles.py -r cubic -s EPSG:23030 -z 3-17 -v mosaic.tiffAt first I've chosen a subset of 30 MrSID and it takes 10 hours and it works. Check here.
After that, I've tried with all the MrSID files and I can't reach to create the mosaic, after two days gdalwarp is at 1% processing the first MrSID.
As a workaround, I've tried to avoid the creation of the big mosaic, I've called gdal2tiles for each MrSID, and merging the shared tiles with imagemagic. The issue with this method is that I need a huge quantity of temporal files (30 MrSID files (90MB) give me around 30GB of temporal files).
Any ideas how can achieve this? Is it possible create such a big mosaic? Do you suggest me another strategy?
MrSID files are like this:
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)Files: test/807-1-3.sidSize is 7355, 4796Coordinate System is `'Origin = (309892.000000000000000,4291525.000000000000000)Pixel Size = (1.000000000000000,-1.000000000000000)Metadata: ICC__Profile=0,0,1,148,65,68,66,69,2,16,0,0,109,110,116,114,71,82,65,89,88,89,90,32,0,8,7,212,0,19,0,2,0,29,0,23,97,99,115,112,77,83,70,84,0,0,0,0,110,111,110,101,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,246,214,0,1,0,0,0,0,211,45,65,68,66,69,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,5,99,112,114,116,0,0,0,192,0,0,0,36,100,101,115,99,0,0,0,228,0,0,0,119,119,116,112,116,0,0,1,92,0,0,0,20,98,107,112,116,0,0,1,112,0,0,0,20,107,84,82,67,0,0,1,132,0,0,0,14,116,101,120,116,0,0,0,0,40,99,41,32,50,48,48,52,32,65,100,111,98,101,32,83,121,115,116,101,109,115,32,73,110,99,46,0,100,101,115,99,0,0,0,0,0,0,0,28,69,115,99,97,108,97,32,100,101,32,103,114,105,115,101,115,32,45,32,71,97,109,97,32,50,46,50,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,88,89,90,32,0,0,0,0,0,0,243,81,0,1,0,0,0,1,22,204,88,89,90,32,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,99,117,114,118,0,0,0,0,0,0,0,1,2,51,0,0 IMAGE__COMPRESSION_BLOCK_SIZE=512 IMAGE__COMPRESSION_GAMMA=2.000000 IMAGE__COMPRESSION_NLEV=8 IMAGE__COMPRESSION_VERSION=2,0,0 IMAGE__COMPRESSION_WEIGHT=4.000000 IMAGE__CREATION_DATE=Sat Jan 12 13:20:09 2002 IMAGE__INPUT_FILE_SIZE=35277072.000000 IMAGE__INPUT_FORMAT=TIFF w/ World File IMAGE__INPUT_NAME=H:\Imagenes\MrSid\Vuelo_Americano\comp\807_1_3.TIF IMAGE__STATISTICS_MAX=255 IMAGE__STATISTICS_MEAN=231.585752 IMAGE__STATISTICS_MIN=1 IMAGE__STATISTICS_STANDARD_DEVIATION=58.039863 IMAGE__TARGET_COMPRESSION_RATIO=10.000000 PShop__ImageResources= VERSION=MG2Corner Coordinates:Upper Left ( 309892.000, 4291525.000) Lower Left ( 309892.000, 4286729.000) Upper Right ( 317247.000, 4291525.000) Lower Right ( 317247.000, 4286729.000) Center ( 313569.500, 4289127.000) Band 1 Block=1024x128 Type=Byte, ColorInterp=Gray Minimum=3.000, Maximum=255.000, Mean=232.406, StdDev=53.985 Overviews: 3678x2398, 1839x1199, 920x600, 460x300, 230x150, 115x75, 58x38, 29x19
