GDal problem "no suitable image found" when I run “ogr2ogr” command
I am trying to run "ogr2ogr" command
macbook$ sudo ogr2ogr -f "PostgreSQL" PG:"dbname=test user=postgres" /Users/macbook/planning.gdb But I am getting this error:
dyld: Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL Referenced from: /Library/Frameworks/GDAL.framework/Programs/ogr2ogr Reason: no suitable image found. Did find: /usr/local/lib/GDAL: not a file I following this answer : Error Updating Gdal with Homebrew
macbook$ export PATH=/Library/Frameworks/GDAL.framework/Programs:$PATH macbook$ which ogr2ogr /Library/Frameworks/GDAL.framework/Programs/ogr2ogr But I am getting this error whenever I run the "ogr2ogr" command macbook$ sudo ogr2ogr -f "PostgreSQL" PG:"dbname=test user=postgres" /Users/macbook/planning.gdb dyld: Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL Referenced from: /Library/Frameworks/GDAL.framework/Programs/ogr2ogr Reason: no suitable image found. Did find: /usr/local/lib/GDAL: not a file When I run : macbook$ ls /usr/local/lib/ I can find the folder :
dtrace libopencv_highgui.dylib gcc libopencv_imgproc.2.4.6.dylib gdal libopencv_imgproc.2.4.dylib
