Functionality of Attribute Assistant and ArcGIS Online
We are an EGIS group using Arc Desktop 10.3.1 and ArcGIS Online as well as the collector app. With ArcDesktop we use the ArcGIS Local Govt Attribute Assistant
We are seeking to allow users to enter service request point data using either the collector app or ArcGIS online yet still retain the functionality of the Attribute Assistant we are using in the desktop version.
Specifically we wish to use the AutoIncrement Number option to give each new service request that has been dropped in the field using the collector or arcgis online a sequentially incremented service request number. Additionally when a point is dropped in the field using the app or online we would like the zip, map page, map block, zones, etc automatically pulled through and populated so the field user only needs to drop a point and enter the problem. (Basically we would like Attribute Assistant to behave in ArcGIS Online/Collector just the way we have it behaving in ArcDesktop)
I have done a decent amount of research here and located this article http://blogs.esri.com/esri/arcgis/2015/01/29/collector-for-arcgis-v10-3-is-out-and-its-a-big-deal/
that seems to say that in 10.3 there will be this functionality, but I can not find out how any one has implemented them in the past. Is this true that is functionality exists? and has anyone had any experience using Attribute Assistant in the Collector or ArcGIS Online environments? And if so how did you go about it?
