Folium heatmap not displaying
I have an output file data.json
[{"5403": 2, "9734": 1, "2565": 5, "5087": 2, "9061": 1, "1761": 4, "4811": 7 "1111": 5, "3891": 3, "1962": 3}]and a shapefile converted to geojson https://www.dropbox.com/s/uou0jxhpklgt8r6/pc4.json?dl=0
I use this code to generate the map in ipython notebook:
import foliumimport numpy as npfrom IPython.display import IFramefrom IPython.core.display import HTMLdef inline_map(m, width=650, height=500): """Takes a folium instance and embed HTML.""" m._build_map() srcdoc = m.HTML.replace('"', '"') embed = HTML(''.format(srcdoc, width, height)) return embed mapa = folium.Map(width=900, height=600, zoom_start=7, location=[52.3, 5], tiles='Mapbox Bright')mapa.geo_json(geo_path='pc4.json', data_out='data.json', data=pcs, columns=["PC4","Count"], key_on="feature.properties.PC4", fill_color='PuRd', fill_opacity=1, line_opacity=1, legend_name='Demand', reset="True")mapa.create_map('test.html')IFrame('test.html', width=1000, height=700)It creates the map fine, just as the output file, but it doesn't overlay any heatmap. It does show the legend though, but nothing else.
I know this question is similar to Geopandas/folium map not displaying but his solution doesn't do anything for me.
