focal statistics with variable radius
is there an easy way to do focal statistics on a raster, with a variable radius for the neighbourhood to be searched? As in: that search radius would be stored in another raster?
i tried something like
f_max = arcpy.sa.FocalStatistics(Tau,arcpy.sa.NbrCircle(rad_ras,"CELL"), "MAXIMUM","DATA")it returns
Traceback (most recent call last): File "K:\Informatik\tools\arcpy\GKPROZ\test_3.py", line 383, in ufereros_gq(r"F:\25sg\25107\TG7\access\gis_logger_tg7.mdb",gq_nummer, False) File "K:\Informatik\tools\arcpy\GKPROZ\test_3.py", line 300, in ufereros_gq f_max = arcpy.sa.FocalStatistics(Tau,arcpy.sa.NbrCircle(rad_ras,"CELL"), "MAXIMUM","DATA") File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 4796, in FocalStatistics ignore_nodata) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 47, in swapper result = wrapper(*args, **kwargs) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 4783, in wrapper neighborhood = Utils.compoundParameterToString(neighborhood, ParameterClasses._Neighborhood) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 75, in compoundParameterToString return str(parameter) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\ParameterClasses.py", line 202, in __str__ self.units]) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\CompoundParameter.py", line 39, in _toString userProvidedPounds = [value == "#" for value in values] File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 3598, in EqualTo in_raster_or_constant2) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 47, in swapper result = wrapper(*args, **kwargs) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 3595, in wrapper return _wrapLocalFunctionRaster(u"EqualTo_sa", ["EqualTo", in_raster_or_constant1, in_raster_or_constant2])RuntimeError: ERROR 000732: Input Raster: Dataset # does not exist or is not supportedalthough the raster(s) exists. I assume this means that the Nbr function can't work with a raster, as the same line works fine for a fixed value for the radius of the circle. I have found a workaround in that i do the focal statistics 10 times with a different radius each time and then use arcpy.sa.Pick to choose from those 10. This is however painfully slow. Is there a better way to do it?
any help would be appreciated.
i use ArcGis 10.0 SP4 on an info license on Windows 7 64
