Flat Map that can go thru North Pole
Is there any map SDK or tool that can show the navigation that passes through the north pole in a flat way? Basically If I use a Mercator projection map it is only flat and cannot show the north part of as how it is seen in a globe. I need something that will show a plane passing through the north pole in a 2D map.
