Finding duplicate records in field using ArcGIS for Desktop?
im looking for duplicate records in dbf files based upon the attribute called 'ID'. I have various dbf files from 500,000 records to 1.5 million and I know there are a host of duplicates.
I would like to add a field 'Duplicate' that says Yes or No (or 1 or 0 is fine) when the ID attribute is present elsewhere. Using the following python script in Field Calculator returns 1 for a duplicate entry and 0 for unique entry;
uniqueList = [] def isDuplicate(inValue): if inValue in uniqueList: return 1 else: uniqueList.append(inValue) return 0 isDuplicate(!FIELD_NAME!) however the 1st record of, for example, 5 duplicate IDs will also be returned as a 0 (the subsequent 4 are considered the duplicates). I would need all 5 to be marked as duplicate as the ID exists elsewhere.
Using the following code will give you an incremental count of how many times that ID occurs with 1 meaning the 1st occasion and so forth;
UniqueDict = {} def isDuplicateIndex(inValue): UniqueDict.setdefault(inValue,0) UniqueDict[inValue] += 1 return UniqueDict[inValue] isDuplicateIndex( !YOUR_FIELD! ) I just want a 1 (or Yes) if the ID of that record exists elsewhere! (ArcGIS version 10.1)
I have seen other answers such as Python script for identifying duplicate records (follow up) but it doesn't quite work.
