I am attempting to calculate the intersection of two circle on the Earth with a given latitude, longitude and radius. I started with this post.
These circle will never be more than 100 km in diameter and will normally be "close" to each other, meaning two intersecting points for the pair of circles.
I added a comment in the code below at the place where I am having the issue.
Any help would be appreciated.
NOTE: I originally asked this question on StackOverflow, but with this being so geospatial, I did not get any answers.
var circle1 = {lat:37.673442, lon:-90.234036, r:107.5};var circle2 = {lat:36.109997, lon:-90.953669, r:145};function findInterscetionOfTwoCircles(circle1, circle2){ var c1 = latLonToGeocentricCoords(circle1); var c2 = latLonToGeocentricCoords(circle2); var r1 = convertRadians(circle1.r); var r2 = convertRadians(circle2.r); var c1dotc2 = calculateDotProduct(c1, c2); // This is where the problem is occurring. // The value of 'a' should be 0.9735030 but I am getting 46.770178816522844. // I am certain that r1 and r2 are correct (match the values in the original post). Additionally, I believe the calculateDotProduct function to be // correct, therefore making c1dotc2 correct. I think I have ruled out // any Order of Operations error. Maybe it is a degree/radian conversion // issue or something like it? I tried different variations and I and now out // of ideas. var a = (Math.cos(r1) - (Math.cos(r2) * c1dotc2)) / (1 - (c1dotc2 * c1dotc2)); var b = (Math.cos(r2) - (Math.cos(r1) * c1dotc2)) / (1 - (c1dotc2 * c1dotc2)); // -45.83805010474024, should be 0.0260194 var n = calculateCrossProduct(c1, c2); var x0 = calculateLinearCombination(a, b, c1, c2); var ndotn = calculateDotProduct(n, n); // var t = Math.sqrt((1 - calculateDotProduct(x0,x0))/calculateDotProduct(n,n)); // Finish the algorithm}function latLonToGeocentricCoords(circle){ var x = Math.cos(degToRad(circle.lon)) * Math.cos(degToRad(circle.lat)); var y = Math.sin(degToRad(circle.lon)) * Math.cos(degToRad(circle.lat)); var z = Math.sin(degToRad(circle.lat)); return {x:x, y:y, z:z};}function geocentricCoordsToLatLon(x, y, z){ var lon = Math.atan2(x,y) var lat = Math.atan2(Math.sqrt((x*x)+(y*y)), z) return { lat: lat, lon: lon};}function convertRadians(radius){ // converts NM right now return degToRad(radius) / 6; }function calculateDotProduct(input1, input2){ if(arguments.length !== 2){ throw new Error('You must supply two arguments to this method.'); } if(Array.isArray(input1) !== Array.isArray(input2) || typeof input1 !== typeof input2){ throw new Error('Inputs must be the same types.'); } var dotProduct = 0; if(Array.isArray(input1)){ // process as parallel arrays if(input1.length === input2.length){ throw new Error('Input lengths must be the same.'); } for(var i = 0, len = input1.length; i < len; i++){ dotProduct += input1 * input2; } } else if(typeof input1 === 'object' && !Array.isArray(input1)){ // process as key-value object for(var key in input1){ if (input1.hasOwnProperty(key)) { if(!input2[key]){ throw new Error('Both inputs must have the same properties to be processed.'); } dotProduct += input1[key] * input2[key]; } } } return dotProduct; }function calculateCrossProduct(circle1, circle2){ var x = (circle1.y * circle2.z) - (circle1.z * circle2.y); var y = (circle1.z * circle2.x) - (circle1.x * circle2.z); var z = (circle1.x * circle2.y) - (circle1.y * circle2.x); return {x: x, y: y, z: z};}function calculateLinearCombination(a, b, c1, c2){ var x = {x: a * c1.x, y: a * c1.y, z: a * c1.z}; var y = {x: b * c2.x, y: b * c2.y, z: b * c2.z}; return calculateDotProduct(x, y);} function degToRad(degree){ return degree * Math.PI / 180;}function radToDeg(radian){ return radian / Math.PI * 180;}
