find edges inside and outside of polygon in NetworkX
Longtime GIS user, but a very new Networkx user. I want to find all routes between points within a polygon, but I do not want routes between points that go outside the polygon. Let's say I define the nodes as such:
import networkx as nxfrom matplotlib import pyplot as plotfrom itertools import combinationsG = nx.Graph()locations = [(1,1),(3,4),(3.1,-2),(6,-1),(7,4),(8,15),(8,29),(6,28),(5,25),(7,24),(5,21),(4,15),(3,13),(2,5)]pos = {} # build a dictionary that contains coordinates of each node in the graphfor i in xrange(len(locations)): pos = locations G.add_path(pos.keys()) G.add_path([min(G.nodes()),max(G.nodes())]) #this closes the last edge in the shapefileOkay, so there is an example of a polygon of interest. If I use nx.draw(G,pos) and view it with plot.show(), I get what I expect (the outline of this irregular polygon). So far so good.
Now, I can create all possible edges between points like so:
combos = combinations(pos.keys(),2)G.add_edges_from(combos)But when I do this, it produces all of the intra-polygon connections I want, but also the exterior ones I do not want. Is there a simple way in networkx to either a) avoid creating those or b) delete those. I will eventually need to be automating this process with thousand of polygons (after importing all their node coordinates)
