Here - http://gisintelligence.wordpress.com/2011/04/19/limiting-xyz-geometry-drift/ I found the description of XY Resolution and XY Tolerance in "Arcgis World".
I have a question - my cadastral data in shapefile format have accuracy 1 cm. So, if I want to work with my data in Arcgis File Geodatabase I should use XY Tolerance 0,01 m and XY resolution 0,001 m ( http://goo.gl/uqDrG
- is that ok? I mean - that values are proper for topology matters and so on?
