<b stylemsobidifontweight normal><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Job Description<span><b><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt> <span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Site inspection and followup of customer water complaints and pipeline emergency works during the shift Update work order inspection sheets for used material and prepare necessary reports do the minor repair work himself assign incidents to Pipe Fitters or contractor amp supervise their work Prepares damage claims in case of Pipeline damage by Contractors.<span>
<b stylemsobidifontweight normal><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Major Duties and Responsibilities<span><b>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Site investigation of water customer complaint and pipeline emergency cases amp reporting.<span stylemsospacerun yes>nbsp <span>Supervises the implementation of emergency pipeline works performed by inhouseoutsource PipeFitters or contractors during normal andor outside shift hours if necessary.<span stylemsospacerun yes>nbsp <span>Ensure that the pipeline works including reinstatement of roadspavements are carried out as per the specifications and requirements.<span stylemsospacerun yes>nbsp <span>Followup Issued contract work requests CWR to the contractors.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Daily update CWR checklist for work progress.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Daily update of water meter details.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Update inspection sheet for the material used in the site after completing the work.<span stylemsospacerun yes>nbsp <span>Prepare shutoff request and coordinates with Operation Section for shut off.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Prepare main laying notification for new pipe laying apparatus installationreplacement and coordinate with GIS surveyors.<span stylemsospacerun yes>nbsp <span>Performs other related duties as needed upon request by Maintenance Engineer or Emergency Shift Supervisor for site investigation of water customer complaint and pipeline emergency cases amp reporting.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Supervises the implementation of emergency pipeline works performed by inhouseoutsource PipeFitters or contractors during normal andor outside shift hours if necessary amp update GIS.<span stylemsospacerun yes>nbsp <span><span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Ensure that the pipeline works including reinstatement of roadspavements are carried out as per the specifications and requirements.<span>
<b stylemsobidifontweight normal><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Qualification Requirements<span><b><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt><span stylemsospacerun yes>nbsp <span>Two years diploma or its equivalent or higher.Knowledge about reinstatement of roadspavements water pipeline main laying and maintenance works.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Job Experience<span stylemsospacerun yes>nbsp <span>Minimum of five 5 years as maintenance field inspector of water networks.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Work Environment<span stylemsospacerun yes>nbsp <span>90 Site work 10 office.<span>
<b stylemsobidifontweight normal><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Other Significant Requirements<span><b>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>To be well aware of the distribution system operations amp Maintenance.<span stylemsospacerun yes>nbsp <span>Knowledge about waterworks materials DCIP HDPE Cooper amp MDPE.<span stylemsospacerun yes>nbsp <span>Familiar with GIS issues.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Have leading skills and able to work independently.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Have a good ability to speak read and write English.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Preferable to know Arabic as well.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Knowledge in using relevant computer operating applications word excel project GIS applications and navigation system Requires<span stylemsospacerun yes>nbsp <span>This position requires good training for ERP system.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Mobilization of resources in resolving emergency conditions.<span stylemsospacerun yes>nbsp <span>Requires Qatari driving license.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>This position requires extensive traveling between venuesdepots during normal and or outside office hours.<span stylemsospacerun yes>nbsp <span>This position requires mobile communication while on duty outside the office.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>This position requires mobile communication outside normal office hours for emergency purpose.<span stylemsospacerun yes>nbsp <span><span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Read amp understand KAHRAMAA specifications for materials and main laying and be sure that contractor implements specifications during work execution.<span>
