How do I input the arc tan in the field calculator given the values of the fields to get the desired answer, I compare the answer of the manually computed arc tan value and the Atan Spatial Analyst tools. the answer that I get from the Atan Spatial Analyst tool is different from the answer that I computed manually. so I want to calculate the arc tan values using the field calculator but how do I input it in the expression box?
