Field Calculator - calculating percentage
So, this is probably quite a basic question, but I can't seem to figure it out right now and still didn't manage to find an answer online.
I have a shapefile containing counties and their respective population for a given area. I woould like to use the Field Calculator to create a new field that contained the % of the total population in each county. I was looking for a way of doing it in one step inside the Field Calculator, i.e., how to build an expression that states something like "divide the population of each county by the sum of the population of all counties in this same column and multiply it by 100". I'm actually stuck in the "sum of all values" part...
Not sure if I'm demanding too much of a simple solution or if I'm just being blindsided and not seeing some obvious answer. Anyone?
Many, many thanks!
