I asked a question yesterday, about splitting polygons using a line, and I ended up using the approach that is described in the comments here.
Although this worked with my test data, it causes a lot of issues when running it with more complex datasets.
Therefore I am working on a new approach, which works fine in ArcGIS, but not outside of ArcGIS.
In the following screenshot you can see my polygons and my line. I would like to have each polygon, crossed by a line, to be split by that line (in this case, each polygon would turn into two polygons).
Here is the workflow:
Step 1) MakeFeatureLayer_management: Create feature layer (because we are selecting the polygons)
Step 2) SelectLayerByLocation_management: Select all the buffers that are crossed by the line, because only those buffers should be considered
Step 3) buffersToBeSplit: iterate over the selection to extract all names, and push them into a list (each buffer has a unique name, which is found in the column Name)
Step 4) SelectLayerByAttribute_management: iterate over the list, and use each name to select the corresponding buffer
Step 5) FeatureToPolygon_management: for each buffer: use the buffer to cut it with the line
Note: I am splitting each feature separately, because splitting all of the buffers at once creates a lot of extra polygons (see comments mentioned above)
And here is the code:
polygon = r"D:\Data\buffers.shp"line = r"D:\Data\line.shp"# Step 1polygon_fl = arcpy.MakeFeatureLayer_management(polygon,'polygon_fl')# Step 2arcpy.SelectLayerByLocation_management(polygon_fl,'INTERSECT',line)# Step 3buffersToBeSplit = []for row in arcpy.SearchCursor('polygon_fl'): buffersToBeSplit.append(str(row.Name))# Step 4, 5i = 0for bufferName in buffersToBeSplit: i += 1 query = '"Name" = \'%s\'' % bufferName arcpy.SelectLayerByAttribute_management('polygon_fl','NEW_SELECTION',query) arcpy.FeatureToPolygon_management(['polygon_fl',line],r"D:\Data\Output\cutPoly%s.shp" % str(i))Proof that the Select by Location works:
And here is the result when I am running this code from the Python console in ArcGIS:
Exactly what I need! Each buffer has now been split into two seperate parts.
Now the problem arises when I am running this code from outside of ArcGIS (PyScripter). The result looks as follows:
You can see that only the very first polygon is split (top left) and all the others are ignored. The fact that each polygon is returned means that the the selection is working fine, but what is not working is the part that uses the line to cut that selection.
I've been trying for quite a while now, and I absolutely cannot figure out why this code would work inside of ArcGIS but not outside.
PS: what I am trying to implement is what can be easily done in SAGA GIS using the Polygon-line-intersection tool . If you are a QGIS-user, you can find the tool in the Processing toolbox.
