Using 10.2 ArcMap/ArcGIS Server on Windows I've successfully published some map services from my PostgreSQL/PostGIS data and now I want to enable editing the features through a JavaScript web app. This is NOT through SDE tables (i.e., creating a geodatabase). Yes, I am using PostgreSQL 9.3.1 and PostGIS 2.1... but everything else seems to work fine but this PK error. How do I get ArcGIS Server to trust me that the incrementing PK I've created is OK?
I began using the serial data type for the OBJECTID primary key which appears to be a shortcut for creating an integer, auto-incrementing key as follows:
CREATE TABLE test_schema.volmonwgs84e( objectid serial NOT NULL, volmon24_i integer, site_id integer, waterbody character varying(30), geom geometry(MultiPoint,4326), CONSTRAINT volmonwgs84e_pkey PRIMARY KEY (objectid))WITH ( OIDS=FALSE);ALTER TABLE test_schema.volmonwgs84e OWNER TO postgres;CREATE INDEX volmonwgs84e_geom_gist ON test_schema.volmonwgs84e USING gist (geom);However, when I go to publish the service (from ArcMap) the Analyzer shows the error above.
Right-clicking the error kindly offers to "Add an auto-incrementing ID" for me, to which it later responds with the following. AFAIK, I ALREADY have an auto-incrementing field anyhow.
"Executing: AddIncrementingIDField testing.test_schema.volmonwgs84e BOOStart Time: Tue Dec 10 15:55:06 2013ERROR 000152: You cannot add an incrementing ID field to a table registered with the geodatabase.Failed to execute (AddIncrementingIDField).Failed at Tue Dec 10 15:55:07 2013 (Elapsed Time: 0.70 seconds)[/CODE]So, what data type and rules need to be on this auto-incrementing field, and what is AddIncrementingIDField trying to do for me?
UPDATE:
Thinking that my issue was the "new" PostGIS/PostgreSQL approaches to things I've also tried creating a table with these older approach as follows:
I know that the database IS maintaining the PK because I can add features using QGIS just fine. AND, ArcMap's properties for the indexes on the layer shows objectid is a unique index.
PS, buried in this excellent link (http://proceedings.esri.com/library/userconf/proc13/tech-workshops/tw_192.pdf) I see that Arc doesn't like fields with quotes (which is how you force CAPS on OBJECTID. Lowercase objectid appears to be just fine to ArcMap, but perhaps not ArcServer.
"00166: Layer's ObjectID is not maintained by the database and the feature service is being published with Create capability enabled"
So, following the JS API examples I am enabling both the geometry service and the Feature Access service with all the Operations and Capabilities enabled.
UPDATE:
- manually setting the sequence on integer PK column instead of using the SERIAL type,
- using "SELECT AddGeometryColumn" to create the geometry column, and therein using the old constraints approach with the final argument = false (http://postgis.net/docs/AddGeometryColumn.html)
CREATE SEQUENCE test_schema.mypoint_const_b_seqINCREMENT 1MINVALUE 1MAXVALUE 9223372036854775807 START 1CACHE 1;
ALTER TABLE test_schema.mypoint_const_b_seq OWNER TO postgres;CREATE TABLE test_schema.mypoint_const_b( objectid integer NOT NULL DEFAULT nextval('test_schema.mypoint_const_b_seq'::regclass), volmon24_i integer, site_id integer, waterbody character varying(30), CONSTRAINT mypoint_const_b_pkey PRIMARY KEY (objectid))WITH ( OIDS=FALSE);SELECT AddGeometryColumn ('test_schema','mypoint_const_b','geom',4326,'MULTIPOINT',2, false);ALTER TABLE test_schema.mypoint_const_b OWNER TO postgres;CREATE INDEX mypoint_const_b_geom_gist ON test_schema.mypoint_const_b USING gist (geom);But I still get a fatal error when trying to create a service with Feature Access "Create" capability enabled with the same message:
كود:
