Fastest way to Join tables in python automation
My issue comes form the fact that doing Joins manually is actually relatively quick (5mins), but python automation of this process is 6hrs! Here is my code:
import arcpy GDB_MARK_TO_MARK_VECTOR_VIEW = "Database Connections\\OLE DB Connection.odc\\GDB.MARK_TO_MARK_VECTOR_VIEW" table = "N:\\Geodetic\\GIS\\BaseLayers\\M2Mlines\\M2Mlines.mdb\\JOINtable" feature1 = "N:\\Geodetic\\GIS\\BaseLayers\\M2Mlines\\M2Mlines.mdb\\UNJOINED" feature = "N:\Geodetic\GIS\BaseLayers\M2Mlines\M2Mlines.shp" arcpy.env.overwriteOutput = True arcpy.CopyRows_management(GDB_MARK_TO_MARK_VECTOR_VIEW,table) arcpy.XYToLine_management(GDB_MARK_TO_MARK_VECTOR_VIEW,feature1,"FROM_REF_UTM_X_M","FROM_REF_UTM_Y_M","TO_REF_UTM_X_M","TO_REF_UTM_Y_M","GEODESIC","M2M_ID", "PROJCS['NAD_1983_UTM_Zone_15N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-93.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];-5120900 -9998100 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision") arcpy.JoinField_management(feature1,"M2M_ID",table,"M2M_ID") arcpy.CopyFeatures_management(feature1,feature) exit() The XYToLine_management does not keep the table and therefore the table needs to be reattached. Is there a way to speed this up?
MAJOR BREAK THROUGH... (For me anyway) I honestly didn't think it would work but I checked all 300,000+ lines in my data table vs "the correct way" above, here is my new code that runs in 4 minutes!:
import arcpy,os GDB_MARK_TO_MARK_VECTOR_VIEW = "Database Connections\\OLE DB Connection.odc\\GDB.MARK_TO_MARK_VECTOR_VIEW" table = "N:\\Geodetic\\GIS\\BaseLayers\\M2Mlines\\JOINtable.dbf" feature1 = "N:\\Geodetic\\GIS\\BaseLayers\\M2Mlines\\M2Mlines.shp" table1 = "N:\\Geodetic\\GIS\\BaseLayers\\M2Mlines\\M2Mlines.dbf" table2 = "N:\\Geodetic\\GIS\\BaseLayers\\M2Mlines\\JOINtable.dbf.xml" arcpy.env.overwriteOutput = True arcpy.CopyRows_management(GDB_MARK_TO_MARK_VECTOR_VIEW,table) arcpy.XYToLine_management(table,feature1,"FROM_REF_U","FROM_REF_1","TO_REF_UTM","TO_REF_U_1","GEODESIC","M2M_ID", "PROJCS['NAD_1983_UTM_Zone_15N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-93.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];-5120900 -9998100 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision") os.remove(table1) os.remove(table2) os.rename(table,table1) exit()
I could still be guided to a new answer yet. I am always looking to improve, so any thoughts are welcome. ô
